p8r head on my ls
Old Mar 2, 2006 | 04:33 PM
91civicb16a's Avatar
91civicb16a
Default p8r head on my ls
Hey, I'm putting a p8r head (jdm b20 head) on my b18b in little while and I was just making sure that i can use a ls timing belt and ls intake manifold. Also will my header work too? Thanks, Zach
Old Mar 2, 2006 | 06:44 PM
Driverman5777's Avatar
Driverman5777
Why are you doing that? You won't see a difference really at all? If anything less because of the restrictive Intake Manifold
Old Mar 2, 2006 | 07:04 PM
dubcac's Avatar
dubcac
I
Everything will work fine...but there's really no point in the swap.
Old Mar 2, 2006 | 07:47 PM
sherwood's Avatar
sherwood
I missed Sean
just for reference sake: the head is slightly better flowing on the intake side (33mm ports vs 31mm)
i'm pretty sure the head just bolts up.
Old Mar 2, 2006 | 08:07 PM
dubcac's Avatar
dubcac
I
It also has 84mm combustion chambers which is good for a 2 liter...but no real point in putting it on an LS.
Old Mar 2, 2006 | 08:22 PM
Driverman5777
Would it be better than an LS head w/ a B20z swap or with this head? Both w/ the B20z
Old Mar 2, 2006 | 08:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The P8R head won't fit correctly without either welding up the 84mm combustion chamber to fit the 81mm bore or sleeving the block to 84mm. The P8R head is a nice head though because it flows about as well as a PR4 head, so good luck trying to get it on there.
Old Mar 3, 2006 | 03:35 AM
91civicb16a
well, if shmoo says it doesn't fit, it doesn't fit. I will just give it back to my buddy. Thanks guys
Old Mar 3, 2006 | 08:18 AM
Provocateur
On permanent hiatus
Keep it. Those heads are extremely rare and could fetch a pretty penny for someone who wants to use it.
Old Mar 3, 2006 | 09:05 AM
dubcac's Avatar
dubcac
I
I have one too...never got around to selling it yet.
