what u think bout this amp sub combo?
http://www.sonicelectronix.com/item_6195.html#specs thats the amp. http://www.sonicelectronix.com/item_5385.html# subs W/box. the subs are 2 ohms so will that amp pump them?
Depending on what you're trying to accomplish and what type of music you listen to. Deep loud bass, or nice crisp music. This would be a nice, loud sorta clean type kind of music. Bass wise, i'd go w/ something different. Just my opinion.
Plus prices for those 2 subs are wayy to expensive..im sure you could find better deals than that.
im going for more bass so would these subs work better?http://www.sonicelectronix.com/item_4945.html#
i would go with the kickers, i think they are pretty loud and still not to dirty compared to audiobahnn. i wouldn't bother with the audiobahnns, i've never been a fan of them and think they were a cheap piece of poop when i use to have to install them.
also you won't be able to bridge you amp with two, two dual ohm subs. you can either go a half ohm, two ohm, or eight ohms. but there is a dual four ohm kicker cvr or change to a mono block amp.
I second that Kickers are a much better brand. I had a pair of 12" Audiobahn's and they would bottom out and distort with 80 watts more than RMS. I actually gave them away to someone. Kicker FTW on this one!
