Intake Manifold before LSVTEC
Old Feb 24, 2006 | 03:05 PM
torn_phoenix's Avatar
torn_phoenix
you would
Default Intake Manifold before LSVTEC
If I go with a new IM (Either Blox or SK2) will it still be compatible later when I want to go LSVTEC?
Old Feb 24, 2006 | 03:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, the bolt patterns are different.
Old Feb 24, 2006 | 07:12 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Just have a custom job done on the stock manifold.
Old Feb 24, 2006 | 11:40 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
no... just wait for the new head (c1 or c5 im assuming) then get the manifold that will fit that
Old Feb 25, 2006 | 06:55 AM
torn_phoenix
you would
Would the same apply for a header?
Old Feb 25, 2006 | 08:28 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Whoops, I guess I mis-read that. So yeah, what these guys said.
Old Feb 25, 2006 | 08:33 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Not where it meets the head, but where it hooks up underneath some mods. will have to be made to make it fit right.
Old Feb 25, 2006 | 10:05 AM
tegbooster's Avatar
tegbooster
don't spend any money till you get the big stuff out of the way... the LS/V is a huge build... and with all respect it sounds like your not 100% positive what to do about it all... are you doing this job urself?
Old Feb 26, 2006 | 11:52 AM
torn_phoenix
you would
I would probably do most of it myself, I'm trying to do enough research ahead of time to see what will be compatible.
Old Feb 26, 2006 | 02:10 PM
tegbooster's Avatar
tegbooster
that's good... just make sure that you are confident in what your doing before you go about anything your not sure what to do... i would also suggest having someone around that knows it better than you.... just so that if things go wrong (and they will) you have another set of hands.... and some easy advice
