b16a1 spark plugs
Old Feb 22, 2006 | 03:54 PM
2ndGenTeg's Avatar
2ndGenTeg
Default b16a1 spark plugs
i just got my car out of the shop about a month ago. i had a new head gasket put in, some wiring, new distributor and alternator and a new ecu installed. this morning i went out to start my car and it started but then died. it started rpm's went up to maybe 2 and dropped to 0 in the matter of a second or two. i tried to start it again and gave it a little gas and it started up just fine. the idle has been kinda rough lately also, does anybody have an idea what the problem may be? i think the spark plugs are bad and plan on changing them tommorrow and maybe some new wires. what size plugs do i need? do they need to be gapped? do yall think it could be something else that caused it to die like that?
Old Feb 22, 2006 | 07:25 PM
Driverman5777's Avatar
Driverman5777
What year is your teg? What Trim?
Old Feb 23, 2006 | 01:12 PM
2ndGenTeg's Avatar
2ndGenTeg
its a 91 ls
Old Feb 23, 2006 | 05:19 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
if ur car is stock... don't worry about the gap... just look for the ones that are compatable w/ 91LS
and as far as size and part #....
standard NGK - BCPR5ES-11
iridium NGK - BCPR5EIX-11
V-Power NGK - BCPR5E-11
Platinum Bosch - FR8DPX
NGK Blue wires - HE56
just to give you a rough idea... NGK blues for the wires....
Old Feb 24, 2006 | 06:35 AM
2ndGenTeg's Avatar
2ndGenTeg
so i need to get stock ls plugs even though i have a b16a1 ???
Old Feb 24, 2006 | 06:38 AM
zodiach's Avatar
zodiach
I had the exact same problem you had, I have a 91 LS also, I had a very rough idle, espoecially when col, I put in the NGK V-Powers and a new cap and rotor, and now it is idling fine when cold and seems to be running better, my plugs were definitely worn.
Old Feb 24, 2006 | 07:33 AM
2ndGenTeg's Avatar
2ndGenTeg
alright thanks guys. i just went out to my car to start it for work. and yea no start. looks like im gonna have a few projects this weekend.
