new Spoon cams in, car falls flat on face in VTEC
HELP!!!!!...my best friend and i just put a set of SPOON cams in his B16a3...the car sounds SICK, but from idle to 2500rpm its so slugish, from there to 5600 it runs like a raped ape, but once it hits VTEC, the damn thing falls on its face...and then gradually pulls harder, but nothing like it did with the stock cams..which is odd...everythings lines up at TDC...the timing checked good with the timing light...the Adjustable cam gears are lined up at 0 deg advance or retard, so im stumped on how to correct the problem...any info would be greatly appreciated
well..my friend has 3 ECUS....with crossovers of 4800,5600, and 5800...whats the best cross over...also..it idles a little rough..im not sure if thats cause the cams need to be worn in or not..its got over 100miles on the new cams..so i dunno what else there is to adj to get it to work right..lol
Definately sounds like VTEC is set too low. What are the specs on those cams?
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Sounds to me like the cam timing isn't optimized for the powerband he wants. Time to get that thing dyno tuned by someone who knows what they are doing.
http://www.randdmotorsports.com/spoonsports.html#civic
says there that they are designed to make power to 9000 rpms
