i have AUTO RSX time for a tranny flush
Old Feb 2, 2006 | 06:36 AM
airtas's Avatar
airtas
Default i have AUTO RSX time for a tranny flush
what should i use?
royal purple ATF, mobil 1, the honda stuff? anything else?
how many quarts will i need, etc? thanks guys
Old Feb 2, 2006 | 09:13 AM
AcuraFanatic's Avatar
AcuraFanatic
Do not flush transmissions. It brings back up metal deposits and recirculates them all around the inside of the bell housing again. Not good.
Completely drain the fluid, and refill it with Honda ATF only. As lame as it sounds, Honda's ATF is engineered for their own transmissions, and transmission failure has been linked to using outside products.
For optimum results, you can drain a few quarts, add in some ATF, then drain again a week later and completely refill with new ATF.
Old Feb 2, 2006 | 09:58 AM
sherwood's Avatar
sherwood
I missed Sean
if the method he suggest is too time consuming drain and fill three times with ONLY HONDA ATF
using anything else will kil your transmission. and is a culprit behind alot of people problems with their transmissions.
Old Feb 3, 2006 | 04:32 AM
airtas's Avatar
airtas
if i went to a local repair shop, im assuming they wouldnt use honda fluid correct? so the average joe smo wouldnt know you gotta use honda thus they are ruining their cars?
also the fluid i want is HONDA ATF Z1? correct?
Old Feb 3, 2006 | 04:35 AM
airtas's Avatar
airtas
how many quarts if i wanna do it all in one day? since i will not be doing it myself?
Old Feb 3, 2006 | 01:38 PM
sherwood's Avatar
sherwood
I missed Sean
the 02-03 manual says it takes 3 quarts, to drain fill 3 times you need 9 quarts.
and you are correct, the right one you need is honda genuine ATF-Z1
Old Feb 3, 2006 | 02:22 PM
airtas's Avatar
airtas
i only bought threee fuck
Old Feb 10, 2006 | 12:51 PM
J-S2000's Avatar
J-S2000
DO NOT FLUSH TRANSMISSION, dont do it.. I have a video strictly about HONDA/ACURA from the different engine specs to street and track performance... you just gotta keep up with the subtitles LOL
Old Feb 10, 2006 | 01:21 PM
sherwood's Avatar
sherwood
I missed Sean
huh... read the thread before you post... lol
Old Feb 10, 2006 | 01:58 PM
airtas's Avatar
airtas
whys the dealer says flushing is better?
