15x7 +35 offset wheels on a 96-00 civic.
Old Feb 1, 2006 | 09:56 AM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
Default 15x7 +35 offset wheels on a 96-00 civic.
Is the offset to low or would it be fine on a civic with mild lowering (1.5"-1.8")
Just want to make sure if its possible or not to run 7" wide wheels with that kind of offset. Thx.
Old Feb 1, 2006 | 11:13 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
It is possible, but you may have rubbing issues depending how low and camber.
I've ran:
15x7 +45
16x7 +38
15x6.5 +38
The +38 offsets have always rubbed for me during turns on a 2.5 inch drop.
Old Feb 1, 2006 | 12:40 PM
supapoopa's Avatar
supapoopa
ok, thanks. I have a bit of tire rub too with the stock teg wheels on 205's when the wheel is all the way left or right. What offset would work the best in 15x7? +40, +42, +45?
Old Feb 1, 2006 | 03:55 PM
asiandoood's Avatar
asiandoood
42-45 should be good.
Old Feb 1, 2006 | 09:50 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I think they will rub. Especially since I ran +38mm offset with -2.5 camber with 15x7" wheels and 205/50x15" tires.
Autocross Help Page
Old Feb 6, 2006 | 12:22 PM
supapoopa's Avatar
supapoopa
Hey were those the Kosei k1's that you ran in 15x7 38mm offset?
These are the new wheels I'm thinking of getting and would like to know what kind of rubbing i should expect on a 205/50 with a mild lowering (1.5 -1.8"). Thx.
Old Feb 6, 2006 | 04:40 PM
randomtask77's Avatar
randomtask77
Wanderer
I guess you could opt for 195/55/15 if you don't mind losing a little tire width.
Old Feb 6, 2006 | 05:07 PM
twinring's Avatar
twinring
If you are going to use them on the street stay away from the lower numbered offset they look awkward when they stick out too far.
Old Feb 6, 2006 | 06:01 PM
CivicSiRacer
Yup ran 15x7" Kosei TS +38mm offset with 205/50x15" Azenis. Now the Azenis are known to be a bit wide, but they rubbed BAD!
Autocross Help Page
Old Feb 6, 2006 | 06:33 PM
supapoopa's Avatar
supapoopa
So you wouldn't recommend them in that offset on 'thinner' 205 tires (es100's)?
I've always wanted a set of the original k1 single spoke design. Any idea where i could get a 15x7 set in at least a +40 or higher offset. Can't seem to find them anywhere.
I'd like to stick with the 205's and lower profile 50 sidewall. I don't want to have to compromise with tire sizes if I'm going to spend the money on a new set of wheels.
