some advice please?
Old Jan 25, 2006 | 08:43 AM
jdmspec's Avatar
jdmspec
1997 jdm Integra type R
Default some advice please?
After a car had being lying up for a while(95 jdm itr) i started and drove it and after the temp settled at its usual spot i noticed the heater wasnt working??
No hot air just cold.
coolant levels are ok, Car is not overheating, Fan comes in on time as usual and basically everything seems fine and the car is being used daily??
Would this be a faulty/stuck thermostat
Any help appreciated
Old Jan 25, 2006 | 09:05 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if it were your thermostat, your water temp would be off. Check fuses first, then check out your heater core under the dash. :dunno:
Old Jan 25, 2006 | 10:11 AM
bambbrose's Avatar
bambbrose
you probably got a pocket of air in your heater core.
Park on a steep hill with the rear of the car facing down the hill.
Bleed the coolant for at least 3 fan cycles.
