Parts for B-18C1 Swap into a 96-98 hatch???
Old Jan 23, 2006 | 11:19 PM
EKgsr11's Avatar
EKgsr11
Default Parts for B-18C1 Swap into a 96-98 hatch???
Whats up everyone....Well i searched this site up and down and couldnt find anything so i thought id ask....Im about to swap by b-18C1 (OBD1) into a 96-98 Civic Hatch (OBD2) I was curious of what i needed. I know i need a rear mount for the engine, but which one?? also i know i need an OBD1-OBD2 converter plug. Anything else im missing????and Where can i find that plug at??? Anything can help. THANKS!
Old Jan 24, 2006 | 06:19 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you will need an Si rear mount and Si front upper driverside mount. You will have to use your stock civic harness, the Integra has a 2 piece harness and the civic has a 1 piece harness. Your better off finding an EX harness from a 96-98 Civic since it already has the vtec wiring. Are you getting a full swap as in axles, shiftlinkage?? You can find an OBD conversion harness on Ebay, or try www.jdmshit.com Try to Find an OBD2 GSR or LS motor would be a little easier
Old Jan 24, 2006 | 09:32 AM
EKgsr11's Avatar
EKgsr11
yea im doin the full swap...what year does the mounts have to be off? and the reason im doin obd1 is i already gotta gsr. im pulling motor out this weekend so i figured easier than selling it and looking for a new one. My engine is about 35 pounds heavier. I hear that its a good idea to change but not needed. But knowing the way imma drive it im SURE im going to get new axles...
Old Jan 24, 2006 | 10:03 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you need mounts off a 2000 Si, you would also need an OBD2 distributor, alternator and maybe injectors, cause your stock civic harness plugs are different.
Old Jan 24, 2006 | 09:37 PM
EKgsr11's Avatar
EKgsr11
Where do u like i can find some wiring diagrams for the ECU?
Old Jan 25, 2006 | 04:26 PM
thomas's Avatar
thomas
pew pew pew
the sticky at the top of the forum also hondaswap.com has a wealth of info
Old Jan 26, 2006 | 08:28 AM
EKgsr11's Avatar
EKgsr11
Thanks alot guys for your help...TEN TIMES BETTER THAN THE OTHER FORUMS!
