clutch or fuel pump?
Old Jan 17, 2006 | 07:51 AM
97civicEXVTEC's Avatar
97civicEXVTEC
Default clutch or fuel pump?
when i put my foot on the clutch a loud thumping noise comes from the transmission are and the whole engine shakes violently.. im already replacing the clutch as it has 150k miles on it anyways. but could it have been the fuel pump? why would the engine shake only when the clutch is depressed and not when its in neutral if it was a bad fuel pump?
Old Jan 17, 2006 | 08:15 AM
teg92's Avatar
teg92
WHAT OK YEAH!
if it was a bad fuel pump your car wouldnt start.
Old Jan 17, 2006 | 08:21 AM
97civicEXVTEC
thats what i thought. a friend of mine said its the fuel pump because fuel isnt being given where its needed. which made no sense because it only did it when the clutch was depressed. thx
Old Jan 18, 2006 | 04:30 PM
critter sit-t's Avatar
critter sit-t
Critter SIR-T
wow so does the shaking happen when the engine is idiling or when you have revvs on it? and is the clutch engaged or dissengaged?
Old Jan 18, 2006 | 05:17 PM
97civicEXVTEC
the shaking only happens when the clutch is engaged. in neutral at idle its perfect.
