for the New York Integra owners...
Old Jan 4, 2006 | 05:49 PM
RoB316's Avatar
RoB316
Default for the New York Integra owners...
does anyone from New York know if a JDM motor will pass emissions tests inn a 96? I hear the wiring for the check engine light and pretty much everything else is entirely different and very hard to get it to pass emissions tests in New York. Does anyone have or know of any truths to this? thanks
Old Jan 4, 2006 | 10:30 PM
rugsr's Avatar
rugsr
How do my taillights look
sorry i dont know but id try asking a dealer.........thay MIGHT know
Old Jan 4, 2006 | 10:36 PM
90CvcDX's Avatar
90CvcDX
kekeke
bring it here to PA you can lick and stick nearly anywhere, some places do both.
Old Jan 5, 2006 | 03:53 AM
honura's Avatar
honura
Seni
Hey both the jdm and usdm motors are the same crap. As long as everything is wired up right you should have no problems. Depending on what harness you are using you should'nt have to mess around to much. Goodluck.
Old Jan 5, 2006 | 04:10 AM
RoB316's Avatar
RoB316
how much wiring is there?? is it a pain in the ass? is it actually worth the extra 10 horse it gives you over the usdm motor?
Old Jan 5, 2006 | 11:19 AM
honura's Avatar
honura
Seni
what car is it going in? what Year,trim, what harness you gonna use?
Old Jan 5, 2006 | 11:24 AM
VTEC02VLAD's Avatar
VTEC02VLAD
03 RSX type-S
Arent the JDM 96 motors OBD1, and the GS-R 96 US motor switched to OBD2 that year?
If thats the case the OBD1 wont pass emmisions in a shell thats made for OBD2 (1996)
Old Jan 5, 2006 | 02:15 PM
RoB316's Avatar
RoB316
the motor in my 96 gsr is all fucked up and i wanted to buy a new motor.
1996 integra gsr it would go in and i dont know what you mean by harness?
Old Jan 5, 2006 | 02:16 PM
RoB316's Avatar
RoB316
96 in the US are obd2, if the jdm motor is obd2, would it work??
Old Jan 5, 2006 | 02:42 PM
honura's Avatar
honura
Seni
Yes. No matter what motor you get it will work. you will be ok. Just make sure that whatever your new motor does not have that the old one did just swap it over. You can take a 90 ls and put it in a 00 and as long as everything needed is hooked up you will be fine.
