brake light going off WTF??
Old Dec 28, 2005 | 01:59 PM
theguy387's Avatar
theguy387
Default brake light going off WTF??
got a 94 ls and everytime I begin to take a turn at high speeds my brake light (e-brake light) goes off and then just disapears not too worried about it just wondering why it's happening. also when I turned on my car this morning the light stayed on for like 5 min. brake is all the way down, dont understand. I have suspension upgrades if that helps.
Old Dec 28, 2005 | 02:10 PM
Brar's Avatar
Brar
mayb while u upgraded ur suspension u pinched a brake line?
Old Dec 30, 2005 | 09:00 AM
bnuk's Avatar
bnuk
top off your fluid. there is a float in cap to the brake fluid resivior that will set off the light. When you accelerate (or turn) hard the fluid sloshes around and the float drops a little.
Old Dec 30, 2005 | 10:12 AM
XSrcing's Avatar
XSrcing
you need to replace your master cylinder reservoir cap. common problem with pretty much all hondas.
Old Dec 30, 2005 | 12:49 PM
theguy387's Avatar
theguy387
wow thanks guys, cool cookies ill do that.
Old Jan 2, 2006 | 01:08 AM
waaBAAH's Avatar
waaBAAH
correct
Old Jan 2, 2006 | 07:52 AM
turbolowmaz's Avatar
turbolowmaz
I had that same problem and topping off did the trick!
Old Jan 3, 2006 | 09:41 AM
gsrsol's Avatar
gsrsol
slow and low
the spring on the switch that turns the light on in the center console could be worn out, or needs to be adjusted.
