Rsx wing to Integra
hard to say...if you can take a look at one in person, measure the distance between the two mounting points and see if your trunk lid is wide enough.
worst case scenario, go to a dealership and just ask if you can make a quick measurement on an RSX spoiler...they should let you do just that
Anything will fit.
The stock mounting holes will most likely have to be plugged and the new ones drilled for the new spoiler to fit. If you are asking if it will bolt into the stock Integra mounting holes, it won't fit.
Why would you want to do that anyway?
if you wanted a larger looking wing, may i suggest the type-r... looks much better and is made for the 3rd gen integras so it should bolt right up, if your heart is set on the RSX wing, it means that you would need to bondo (and repaint for the clean look)...and drill new holes for the wing... but if u really want i'd still suggest the type r wing
Originally Posted by KaBlookie
^^ maybe he's going for the unique look...who knows.
that is, of course, IF and only if he's thinking about the big squared-off RSX spoiler, and not the smaller "stock-looking" one.
anyway, chances are any wing will fit on your car one way or another. the real question is, will it look good. i'm gonna go out on a limb here and say no, no it won't.
not to mention the shape of the RSX over the shape of the integra....the rsx is much larger than the integra...so as it may look good on that car...on an integra...thats a fairly large wing
