questions about my 99 civic si
Old Dec 1, 2005 | 06:26 PM
seamz9's Avatar
seamz9
Default questions about my 99 civic si
yo0o i have a 99 si and im about to turbo charge it... wut else do i have to do to the engine so that this car will still last me a long time with the turbo ... im thinkin bout boosting 12 pounds thanks
Old Dec 1, 2005 | 06:44 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Well, if you want to boost 12 pounds you'll need new rod bearings, rod bolts, rods, and might as well get some new pistons while your at it. Head studs would help a great deal as well. It's a different story if you want to boost 6-8.
As for the rest of the shit you'll need bigger injectors, an adjustable fuel pressure regulator is nice to have, adjustable cam gears, maybe a walbro fuel pump, chip your ecu and have it tuned unless your using the AEM or Greddy box.
Old Dec 1, 2005 | 08:47 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
you cant just start out at 12 psi, unless you wanna have a reason to rebuild it, yeah Omniscient is right, new rods, bearings, etc. build it for boost!
jdmeg6hatchy
i
Old Dec 2, 2005 | 05:16 AM
seamz9's Avatar
seamz9
Default ok thanks
hey guyz thanks for the info but u said it would be a different story if i was boosting 6-8 ... wut do u mean by that im not really sure if i wanna throw so much money into rebuilding the motor but 8 doesnt sounds to bad either wut do i gotta do for that much thanks ..
Old Dec 2, 2005 | 05:25 AM
jdmeg6hatchy
i
how many miles are on the SI? 6-8 is a safe setting.
Old Dec 2, 2005 | 05:32 AM
seamz9's Avatar
seamz9
it has 82,000 ... yea i kno thats wut everybody has been tellin me but i still dont kno wut else i gotta do to keep the car reliable
Old Dec 2, 2005 | 05:57 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
how much power do you want? thats what is important... not pressure levels
Old Dec 2, 2005 | 06:26 AM
b16ahybrid's Avatar
b16ahybrid
Thank you.:goodjob:
All the other posts above are as worthless as the original post.
Without know anything about his potential set-up you can't advise him accuratly...
12psi means NOTHING.....
Tune your motor for a desired power level, invest in your tuning, and you'll be all good.
What are you planing to tune with (engine management)?
What size of turbo?
Whats your budget?
How much power do you want.
Your motor can handle a little over 300whp with good tuning for daily driving.
Tuning and actual power made determin the limits of a motor, not some boost level.....
