????camber Kit????
Old Nov 30, 2005 | 10:39 AM
SOCALDC4's Avatar
SOCALDC4
Default ????camber Kit????
What Dose A Camber Kit Do??? And Is It Easy To Install Or Adjust??????
Old Nov 30, 2005 | 11:16 AM
FooD2000's Avatar
FooD2000
Still Water
First of all, Where did you hear about this and why are you interested in it? What's your current suspension set-up?
Old Nov 30, 2005 | 01:53 PM
SOCALDC4's Avatar
SOCALDC4
Eibach Sport Springs And I'm Picking Up Som Kyb Gr 2 Shocks
This Weekend I Am Installing
Old Nov 30, 2005 | 02:00 PM
FooD2000's Avatar
FooD2000
Still Water
what does a camber kit do? it's just upper adjustable ball joints that help your shop's job with the alignment. I would suggest getting them with the eibach sportline drop. So that you can just get your car aligned once.
Installing them is very very straight forward.
Here's a diy: http://www.team-integra.net/sections...?ArticleID=783
Old Nov 30, 2005 | 02:45 PM
SOCALDC4's Avatar
SOCALDC4
So I Dont Really Need Them????
Old Nov 30, 2005 | 05:49 PM
SOCALDC4's Avatar
SOCALDC4
Old Nov 30, 2005 | 06:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, you don't NEED them, but they are good to have if you give a damn about your handling characteristics.
A basic toe alignment after any lowering will eliminate any chance of premature tire wear.
Old Nov 30, 2005 | 06:23 PM
SOCALDC4's Avatar
SOCALDC4
Ohhhhhhhhhh!!!!
Old Nov 30, 2005 | 11:48 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
haha yes...they are a good idea...specially if ur doing the sport instead of the pro...if ur going for handling anyway...pro is the performance oriented drop whereas sport is just the look-good drop....not sure what ur handling goals are
Old Dec 1, 2005 | 09:05 AM
Brar's Avatar
Brar
^i thought sport would be more performance...i want good handling, my handling is already pretty good with the stock suspension alone...but wat would make it better?
i wanna get the Koni sport (yellow) with either pro or sport. my tires right now are 204/40r16 and it has a 3" gap in the front and 2" in the back. im going to get 45s installed this sat so i duno wat the gaps would be then. but wat would give my car that nice drop look? would sports be too low? im also getting the ingalls camber kit
