Back passenger window
Old Nov 23, 2005 | 06:40 PM
assante74's Avatar
assante74
Default Back passenger window
I have just bought a 1987 honda accord lx and the back passenger side window was riccocet out by a weed whacker. I was wondering how would I put in a window that I have just bought from the pick and pull?
Old Nov 25, 2005 | 09:02 AM
m735is's Avatar
m735is
Just reverse the order you used to pick and pull the used one.
It's really not too difficult. Once you get the panel off and take off the plastic, everything is pretty visible. You will have to use the window switch to work the regulator for better access to the bolts that hold the window up. While your in there, grease up the outer handle parts, mine seem to get corroded pretty quick making the handle stick.
Old Mar 29, 2008 | 09:46 PM
goldex420's Avatar
goldex420
pretty mch
