Gear Grinding in 3rd for Si
Old Nov 20, 2005 | 10:36 PM
SIdogg's Avatar
SIdogg
Default Gear Grinding in 3rd for Si
I noticed that 3rd gear on my Civic Si EP3 tends to grind a bit especially when shifting at higher RPM's and speeds.. anyone else experiencing the same problem??
Old Nov 21, 2005 | 03:57 AM
DC5TypeRIntegra's Avatar
DC5TypeRIntegra
Pres. Of DominantDesigns
no i not trying to be a dick but your either not pushing the clutch in far enough while shifting or you need practice...unless you bought it used then the car was beat to shit. there is no way that tranny should have any type of problem... honda makes the best shit around.... i have a 92 prelude with over 180000miles still on the same trany and shifts as good as new.....
only thing i can say is check if it needs som adjustment with you shift linkage but until you do that double clutch so you dont make it worse.. grind is the first sign of a bad tranny
Old Nov 21, 2005 | 02:14 PM
crazy's Avatar
crazy
Tons of people have had problems with grinding in the Type S and I think with the K20A3s too. Honda isn't perfect.
Old Nov 21, 2005 | 07:39 PM
Lvep3's Avatar
Lvep3
I had the same problem when i bought my car, it only had about a 1k miles. he said the 3rd gear synchro took a crap
Old Nov 22, 2005 | 09:55 PM
rsxsti's Avatar
rsxsti
Yeah, i got that problem in my type-s and i bought it to the dealer and they said "road test car shifted thru all gears could not duplicate customer complaint this time tramsmission working normal" but damn.. i still having problem w/ it
Old Nov 23, 2005 | 10:28 AM
SIdogg's Avatar
SIdogg
Default Double Clutching (on 3rd)
Tried double clutching when shifting in 3rd, and noticed no grind or clunk. So looks like the diagnoses may be in the synchros... is this covered under the powertrain warranty?? (i only have 32,000 miles)
Old Nov 27, 2005 | 05:56 PM
Lvep3's Avatar
Lvep3
yeah so dont worry just make sure you take care of it before base warranty (ends at 36k i think) is up. if they cant verify it tell them you go on a test drive with them
Old Nov 28, 2005 | 03:37 PM
ED9man's Avatar
ED9man
driver
Welcome to hell.
Old Dec 9, 2005 | 07:53 AM
J-S2000's Avatar
J-S2000
Yo i just posted that same issue, Yo im having problems with 3rd gear aswell... She would grind it from time to time
Old Dec 9, 2005 | 08:14 AM
VTEC02VLAD's Avatar
VTEC02VLAD
03 RSX type-S
k20 3rd gear problems right here
