JDM B16 Pistons??
Old Nov 20, 2005 | 12:20 PM
rampage918's Avatar
rampage918
Default JDM B16 Pistons??
I believe my head gasket is bad and when I go get it changed I was going to do my pistons at the same time since it will be right there. What pistons does everyone suggest for all motor. I'm not trying to go to make it a weekend car only but make it pretty powerful for daily driving.
Old Nov 20, 2005 | 01:24 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
in order to replace your pistons you would need to remove the oil pan and the whole bottom end of the engine. expect your car to be apart for a weekend to do this right.
Old Nov 20, 2005 | 03:04 PM
rampage918's Avatar
rampage918
Ok. But my main questions is what kind of pistons should I get.
Old Nov 20, 2005 | 03:33 PM
1995Civic's Avatar
1995Civic
I hate ricers
It would really help if we knew what motor we are talking about here.
Old Nov 20, 2005 | 03:34 PM
rampage918's Avatar
rampage918
I have a Jdm B16a2
Old Nov 20, 2005 | 03:43 PM
bambbrose's Avatar
bambbrose
I'd stick with pr3 in that case if doing an oem build. 10.4 compression is more than enough. there are a few people with well over 200whp with less than 11:1.
I would mill the head slightly to get some compression, and run a thinner headgasket.
When you reassemble the engine you might want to get the rods renotched for GSR rod bearings as they are skinnier and made of better material than b16's. it'll be good for a few ponies and add reliability.
Old Nov 20, 2005 | 04:00 PM
rampage918's Avatar
rampage918
So I should definitely get either used gsr rods or new ones? and Pr3 are civic type-r right?
Old Nov 20, 2005 | 04:38 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
pr3 are USDM b16a pistons. pct are CTR pistons.
Old Nov 20, 2005 | 05:58 PM
rampage918's Avatar
rampage918
So I should just stick to the ones I have? So what about if i want to upgrade the head. I know I said I didnt want no like 10 second car but I want to build the motor to have power. Do you think my block is fine and I could just do the head?
Old Nov 20, 2005 | 06:49 PM
Nelson's Avatar
Nelson
Administrator
I have a Jdm B16a2
There is no such thing as a JDM B16A2
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
