Installing an engine?
Old Nov 15, 2005 | 07:13 AM
PunkAssKidThe1s's Avatar
PunkAssKidThe1s
Team Babu
Default Installing an engine?
How hard is it to install your own engine (bolt-on and play such as H22 in an Accord)? I'm not exactly the best mechanic - hell, I went to a shop to have my header put on, but I want to learn, and one of my uncles had to fork out $1,000 for a new engine to be installed into his Subbie!
So, how hard it is and what tools outside of the standard nuts/bolts/screws/drivers/wrenches would I need for this??
Thanks!
PunkAssKidThe1s
Team Babu
Oh, yes, and same question for tranny... Afterall, I've got an AT matted to an F22 in my Accord SE (97)...
Old Nov 15, 2005 | 12:33 PM
97civicEXVTEC's Avatar
97civicEXVTEC
air tools is a must..
if you cant install your own header, i would do a lot more research before you take on something like that..
Old Nov 16, 2005 | 03:57 AM
Altern8r's Avatar
Altern8r
ye i agree with 97civic*** as it is a lot more complicated than a header. that is simple.
Old Nov 21, 2005 | 07:51 PM
96HawkCnvt's Avatar
96HawkCnvt
Thanks!
It's really not that difficult to do stuff like that and I'd encourage you to give it a try. But as others have pointed out, there is a lot more to it than just installing a header. My suggestion is to find some guys locally that you know you can trust and see if you can get some help with it. You'll learn a lot if you aren't afraid to give stuff a try. Just be smart about it so you don't cost yourself a lot or end up with a safety issue etc.
Good luck!
Todd
Old Mar 29, 2008 | 09:48 PM
goldex420's Avatar
goldex420
installin a header takes 10 min a engine 4 hrs or so if u know what ur doing and ive done plenty its quite a job and i KNOW ur not ready
Old Dec 27, 2008 | 10:31 AM
willpower101's Avatar
willpower101
To swap an engine? I don't think so. Tons of people do this job with standard tools, and the saying that they are a "must" is simply misinformation.
Besides standard tools and a ball joint separator the only other thing that makes the job much easier is an electric impact wrench.
Old Mar 19, 2009 | 09:43 AM
donta's Avatar
donta
How hard is it to install a tranny in a 95 Accord. I need to get step by step instruction as to how it should be done.
Old Mar 25, 2009 | 12:27 PM
marvinp8700's Avatar
marvinp8700
if the price is fair
Haynes manual
Old Apr 25, 2009 | 10:39 AM
jrgoswick's Avatar
jrgoswick
Some old guy!
I recently assisted Specialty Performance in Rogers Arkansas install a KillerB into a Civic. Took about 2 hours for the motor AND tranny! It is a lot of work. The ONLY thing I can't say enough-MAKE SURE YOU'VE GOT THE RIGHT TOOLS FOR THE JOB!
