Back Tire, LS
Old Nov 14, 2005 | 05:42 AM
Caldokid83's Avatar
Caldokid83
Default Back Tire, LS
So i guess the bolt is broke, But it is spring loaded so its a Beatch' to get out, Anyone have any suggestions?
I think the pic loaded? Check it out, I took a pic of what i mean
If anyone knows the answer, Can u email me or hit me on aim EroticoUOMO
THANKS!
File Type: jpg
Old Nov 14, 2005 | 08:30 AM
tgansert's Avatar
tgansert
is all good
Maybe I missed something.. Waht is it you are trying to get out? The bolt? If so, and the hole it is in is not threaded, you can use a long, thick (but not too think) shaft and a hammer to smack it out. If it is threaded, you'll have to use a reverse bit or a regular metal bit and a tap and die.
If I'm completely off base, reply and specify what you are trying to remove..
Good Luck.
Old Nov 14, 2005 | 10:03 AM
Caldokid83's Avatar
Caldokid83
thank god someone replied!
in the photo, you only see one side of it. the bolt is half on, its broken. What you see is one side of the bar thing that isnt connected to the bolt because it is broke. Which is why my tire hasn't fallen off yet.
i have tried to tap the bolt out, it wont budge, Ive tried to use a wrench etc to take the nut off the back but when i try to take it off, it springs back into place. so im not sure how to get the bolt off so that i an put a new one in and connect both sides of that arm.
Old Nov 15, 2005 | 05:01 AM
teggyls's Avatar
teggyls
J-villan
your gonna have to drill it out. use a jack to jack up the arm to eleveate some tension. on the backside of it is a welded nut, dont mess those threads up.
Old Nov 15, 2005 | 12:41 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
yeah, its a thing that happens to any honda that ive ever done suspension work to, theres always a bolt somewhere that breaks!
