testing alternator????
Old Nov 11, 2005 | 07:29 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Default testing alternator????
I have a 1995 Integra LS, i purchased a alternator/battery tester today at autozone, it say to hook the gound up to the ground, and the red+ to the alternator, but where on the alternator????
Old Nov 11, 2005 | 08:26 AM
rugsr's Avatar
rugsr
How do my taillights look
i took my civic to a shop and to test the alt. they hook both ends to the battery terminals. they got a reading of 12volts, which means that the battery was not being charged cuz it should say 14.4ish. WHICH means that the alt was dead, replacing it saturday. BTW car has to be running. ALSO while its on the battery give it some gas, it should increase. if it doesnt then it is your alt. check your grounds first though
Old Nov 11, 2005 | 01:02 PM
jdmeg6hatchy
i
cool, thanks. yeah I knew the car had to be on :lmao:
Old Nov 12, 2005 | 12:11 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
it always helps to ask em what they did as you bend over and hand them your money honda$$acura.....u learn as u pay that way next time it happens...u get to do the bending!
Old Nov 12, 2005 | 05:38 AM
jdmeg6hatchy
i
gotcha
Old Nov 12, 2005 | 01:08 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
When your car is running undo the neg. terminal of the battery. If the car stays running your alternator is doing the job, if the car dies there is your answer.
Old Nov 12, 2005 | 10:15 PM
jdmeg6hatchy
i
serious????
Old Nov 13, 2005 | 01:00 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Originally Posted by jdmeg6hatchy
serious????
Yes, serious as a heart attack. You've never heard of that elimination process? The alternator carries most of the weight in powering the car. If it is not running correctly it won't run your car with battery un-done.
Old Nov 14, 2005 | 05:55 AM
jdmeg6hatchy
i
sweet thanks! ill do that!
