OEM Foglight Installation
I just purchased a set of OEM foglights (by Esuse) for my 2001 Civic EX coupe. The box was sealed but there are no instructions. The lights came put together with all of the wiring pre-done (in harness form) and included one relay, the switch, and all the hardware. I've studied the wiring diagrams and taken the underside of the dash apart trying to figure out where evrything plugs in. I remain with 2 4-prong plugs (one red wire and one blue) and 2 1-prong plugs (one must be power->it goes to the fuse, the other is blue and appears to belong outside of the firewall). I found instructions for a very similar product for my car but my harness has a significantly fewer amount of and different kind of plugs so now i am confused. Please help if you can. Thanx
Those are the exact instructions i already looked at but my interior harness is very different than that one. It makes me think i have the wrong wiring harness but i doubt it. I beleive those instructions are actually from honda, and if thats the case im screwed. Everything else like the light and housing itself is exactly the same. I even tried looking at instructions for different trim models and years. Basically there is a plug for the switch, 1 for the relay, 1 for power, 2 4-prong plugs but with only 1 wire in it (1blue 1red/blk) and a random 1 prong with a blue wire. If i need all the other plugs in those instructions than im toast.
