best instake piping for a turbo?
was doing some reading and I guess that intake silicion piping is better then regular piping. this was on DIYNETWORK.com. anyways they did this on a WRX. reason behind this was one, that the curves were less violent, easy to route and the inside as smoother. SO before i start buyingpiping i wanted to ask if I could do this no the GSR. piping is piping BUT for the WRX it was custom made with the BOV port.
http://cgi.ebay.com/ebaymotors/2-5-x...QQcmdZViewItem
check out the specs: says can be used for turbos,
High quality 3-ply or 4-ply fabric reinforced silicone
Heat tolerance: -40° to 392° Farenheit
Burst Pressure: 200 PSI
Working Pressure: 50 PSI
Wall Size: 4 mm - 5 mm
im thinking why not use this for all intake piping from filter to turbo, turbo to intercooler, from intercooler to IM. ONLY THING IS putting a port in for the BOV. THINK THIS IS POSSIBLE?
thanks
thanks
