Is this clutch wear?
you should check your fluid like teg92 said, I had the same problem and I checked my fluid and only a few drops were left in the container, I filled it and everything was fine, although it could also be the wear of your plate just like txhatch said
Originally Posted by dank24
where is the tranny's dipstock located? I see a black rubber piece covering a tube going into the trans. Is it sapose to be there?
you need to check it the old fashioned way and get underneath the car and find the filler plug
I doubt it's the problem (trany fluid) but If I were you, this would be a great time to change it. Buy 2 qts of 10w-40 motor oil. Drain the tranny from the bolt that has a square hole for your 3/8ths ratchet. Replug the drain and then fill the tranny with a funnel and hose untill it runs out of the filler hole (17mm bolt that is above and behind the drain hole).
More than likely, it's your clutch fluid. Have you look for what I said in my last reply yet?
