oil change problem....
okay soo i changed the oil in my teg tonight....wasnt burning oil before i did and now im burning a butt load of it...watd i do and wat can it be??? help.....am i being a newb or wat...help
brandon
brandon
are you sure its not extra oil that spilled on the exhaust? are you smelling it or are you seeing a drop in the oil level in the dipstick? keep in mind, you might have to add some oil after you fill it up and run it cuz the oil filter holds a bit of oil also.
Is the area around (below and behind) your valve cover oil filler cap saturated with oil? [overfill/spill]
Is the bottom of your oil pan saturated with oil after driving? [overfill/spill]
By burning oil, are you smelling it or noticing a drop on your dipstick or oil light?
yes its burning it i can smell it really bad......chckd the oil pan and everything and i dont see anything diff.....soo now im really lost on wat it could be.....was also thinking about rebuilding it since it never has been rebuilkt....is that a good idea or no
It is probably just burning the extra that spilled onto the exhaust. I would get underneath and make sure you don't have a leak that is causing it to fall on the exhaust pipe and burn.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
