Strange squeak/scratching noise...
Old Nov 3, 2005 | 05:17 PM
9600baud's Avatar
9600baud
JDM rox ur world
Default Strange squeak/scratching noise...
Test drove a 98 GSR today. Whenever making "sharp" (sharp being really light actually) left turns, a loud scraping noise comes from the rear right. I have no idea what it is.... I took a look at the upper mount bolts and they looked fine... what could it be??
Old Nov 3, 2005 | 08:18 PM
travis in wa's Avatar
travis in wa
Wheel bearing? Grab that right wheel and give it a shake. Probably better if you lift it up.
How many miles are on it?
Old Nov 3, 2005 | 08:51 PM
dubcac's Avatar
dubcac
I
Possibly wheel bearing...maybe worn bushings?
Old Nov 4, 2005 | 12:20 AM
TribAI's Avatar
TribAI
Wannabe Gearhead
My Integra makes noises like that (I think). What causes it on mine is that the car was in an accident and the sound is from the tire rubbing the edge of the fender, the fender got moved in about a half inch. It kinda sounds like a squeaky spring or something but it's actually just rubbing.
Old Nov 4, 2005 | 05:45 AM
9600baud's Avatar
9600baud
JDM rox ur world
Hey theres 130k miles on it. If i shake the wheel, what am i looking for?
Old Nov 4, 2005 | 06:35 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
is it completely stock??
Old Nov 4, 2005 | 07:00 AM
9600baud's Avatar
9600baud
JDM rox ur world
Yes it is, bone stock
Old Nov 4, 2005 | 07:05 AM
travis in wa
Grab the wheel and pull it towards yourself, like you want to pull it off the car. Any movement or wiggling indicates something wrong with the bearing or hub. It might click, thump, or rattle.
If you can lift the car, slowly spin the tire and feel for grating or rubbing.
It might just be worn brake pads.
Old Nov 4, 2005 | 07:26 AM
9600baud's Avatar
9600baud
JDM rox ur world
Hey Travis, thanks ill do that. Its not the pads because I know what that sounds like and its definitly during "hard" turning when the weight of the car pushes onto it.
How expensive is to replace the bearing/hub?
