Master brake cylinder problem
Old Nov 1, 2005 | 06:18 PM
Zzhatch's Avatar
Zzhatch
Default Master brake cylinder problem
I am in the process of changing the master brake cylinder on my 92 f door civic. i just can not get it to work.
My main problem is the screw on the master brake cylinder between the feeding lines. If i tighten it up the brakes dont work, if i release it i have pressure and it works but it leaks! i dont know what to do i was hoping someone could help me.
thanks
Old Nov 1, 2005 | 09:45 PM
bambbrose's Avatar
bambbrose
I'm pretty sure you weren't supposed to mess with that screw. Tigthen it up. bench bleed the master cylinder, install it, and then bleed all your lines, starting with the drivers front, passenger rear, passenger front, and drivers rear in that order. Bleed with a friend to make sure all the fluid is out. its also nice to get a fluid dye, like blue, so you can tell when all the old fluid is out and new fluid is in
