turboing a da, what else do i need
Old Nov 1, 2005 | 04:38 PM
INTEGRAted_da's Avatar
INTEGRAted_da
Default turboing a da, what else do i need
I have a 93 integra that I am in the process of turboing. I have a fmic, piping, vortec bov, revhard manifold, and am having a turbonetics turbo custom made for my car. Those are the turbo parts I have now. I know I need an external wastegate, downpipe, and oil lines still. As for the car, I havent done anything to the internals yet, but I have an Exedy stage 2 clutch with an 8lb flywheel, and a chipped ecu. I am not sure about the fuel system. I know it will work at low boost with out doing anything, but if I do get fuel parts, I have to keep the boost down anyways because of stock internals.
Can anyone give me some pointers for where to go from here? Might be about 6 more months before I can rebuild my engine.
Thanks a lot for helping me out.
Old Nov 1, 2005 | 04:45 PM
teg92's Avatar
teg92
WHAT OK YEAH!
what are you doing for fuel management? You can run from 6-10 lbs of boost on stock internals without any problems. A buddy of mine is running 11lbs on stock internals and he makes 205WHP. Its also alot in the tuning and what kind of fuel management you go with
Old Nov 1, 2005 | 05:04 PM
INTEGRAted_da
I was thinking about a Super AFC II to deal with the fuel management, but I really cant afford a hondata.
Old Nov 1, 2005 | 05:27 PM
teg92's Avatar
teg92
WHAT OK YEAH!
look into Uberdata or Chrome for tunning, fairly cheap and it gets the job done. Its not as good as Hondata but it will do
Old Nov 1, 2005 | 05:51 PM
INTEGRAted_da
about the uberdata, I found one on ebay and all it looks like it is, is a chip for your ecu. Is that a true Uberdata? because I have a performance chip in my ecu already that adjusts my fuel and timing curves, or is the Uberdata something different?
