Engine cleaning
Old Oct 29, 2005 | 09:17 PM
redgoober4life's Avatar
redgoober4life
I eat plastic.
Default Engine cleaning
So I did have a nice page set up for this, but....well....
Anyway...
The commonly asked "how do I detail my engine?" question is a bit scary for me to answer. On one hand I love relaying information and know-how to anybody that is willing to learn. On the other hand there is a lot to mess up in an engine bay. There is always a slight risk with detailing of undesirable results. The mistakes are usually fixable. Even with this engine detail, I managed to use the wrong metal polish and tarnish what used to be a shiny surface. Always read the labels of what you are using and understand that, usually, the people that make the product know best.
The first step is to look in the engine bay and find the starter, the alternator, a fuse box, and any various other electrical connections.  Wrap these with aluminum foil. "What should I cover?" There's no direct science about this, cover everything that you think should not come in contact with water.  Aluminum foil isn't going to protect against a copious amount of water or degreaser, but if care is taken when spraying with a hose it will be more than sufficient at keeping key components dry.
Rinse the engine with water. This is to loosen any dust or dirt. Do not spray with a stream of water. Always spray with a mist pattern. Do not douse the engine here.
Spray the engine bay down with degreaser. Spray everywhere. Allow to dwell in the engine bay for a few minutes. This will help loosen dirt and oil to make cleaning easier. Use a degreaser that is readily available and not expensive. Avoid formulas that warn against use on aluminum. Read the label. I used wheel cleaner, because that's what I had available.
Remember to clean the front of the engine bay near the radiator. This is a great place to wax when you are done. It's common for cars to start rusting here.
Also spray the firewall. It may not be possible to clean the entire firewall, but a partially clean firewall is better than a dirty firewall.
There is no way around scrubbing. It takes awhile and it is detailed. Here I am using a regular nylon scrub brush, which is good for larger surfaces and caps. I like to work one section at a time, trying not to miss any parts of the section. Alternate between brushes. It's inevitable that you will miss cleaning some little part. Cleaning section by section will help to prevent this.
This is a spoke brush. As the name implies it is very good at getting between two close objects. It works very well for wheels, and it works very well for engine bays. I think I got this one at Big Lots.
The part of the valve cover near the oil cap will be one of the dirtiest parts of the engine.
Now is a great time to retire your toothbrush. It's a great tool for getting in between places the other two brushes won't. You may need to spray more degreaser. Take care around the spark plugs, distributor/coil pack. It's not necessary to cover these if you are careful.
As you scrub along you may notice that the dirt is just going to dry back up onto the surface of whatever you cleaned. To prevent this, as you finish a section dry the section. This will also help with cleaning.  This is the finest 80s towel I could find. Bath towels are usually not a great idea, but for engine cleaning they're great--the polyester is nearly indestructible.
You may wish to do a little metal polishing while you're at it. This should be done after you're done cleaning the engine, and when it is mostly dry. Be careful with flammable polishes, and ones around chrome. This Noxon caused my intake, which used to be bright chrome, to look fairly...brushed. I don't mind too much, but I would if I really wanted chrome underneath my hood. What I'm trying to say is read the product's label.
Yes that is a latex glove. To help prevent wasting metal polish which is sometimes very expensive, wearing a latex glove to apply the polish works great. Most of it ends up on the metal and not in the cloth. Wipe the polish remaining polish with a towel.
After cleaning, drying and polishing the rubber may look somewhat dry. One easy solution is to just spray tire foam on the rubber. A trick is to use a floor wax type product like Future or Mop and Glow to give plastic a satin look. I didn't have a whole bottle, and I wish I would have. It works very good. I do question how it affects the longevity of the hoses, and I would not advise getting it near any accessory belts. However if you're careful where you pour it, you can walk away and in about 15 minutes it should be dry to the touch leaving the plastic and rubber with a nice look.
Remember to clean the underside of the hood with a diluted mixture of degreaser. Follow with a cleaner wax. The underside of hoods are where many cars start rusting.
I really don't like rust, so I decided to step up to Collinite Insulator wax after the regular cleaner/wax. I waxed the underside of the hood, the inner fenders, and the front above the radiator. This stuff is great, and it will soon be on my paint for winter--it is extremely durable, has a wet look, and is easy to use. I didn't want to make product endorsements in this, but Insulator wax is just that good.
The engine should look clean and dressed now. The paint surrounding should look clean and protected. You may wish to go back and wipe the starter and alternator if you want. I did only slightly, as I didn't want to spray degreaser near them. The exhaust shield is corroded, and it makes an otherwise fairly clean engine bay look somewhat dirty. It's daily driven, so some defects are to be expected.
Old Oct 29, 2005 | 09:19 PM
AcuraFanatic's Avatar
AcuraFanatic
The only thing I ever cover up if I detail a motor is if they have an open element air filter. The rest is pretty much common sense, I don't keep the hose over the fuse box, cap/rotor, plug wires, etc. for a long period of time. I use a 1200psi pressure washer and no problems. h:
Old Oct 30, 2005 | 02:00 PM
Nelson's Avatar
Nelson
Administrator
Corey you can come hose down my engine bay.
That didn't sound right :noes:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 30, 2005 | 04:05 PM
TypeG's Avatar
TypeG
why would you use aluminum foil? it is conductive, good way to short stuff out. the starter has a lead wire from the batt.
A trick is to use a floor wax type product like Future or Mop and Glow to give plastic a satin look. I do question how it affects the longevity of the hoses
why would you use floor cleaner on your engine?
what do i know? later.
Old Oct 30, 2005 | 05:44 PM
redgoober4life
I eat plastic.
Okay, so, if it were that easy to short out the starter then I would have problems starting my car on a rainy day.
The floor wax creates a nice finish on the rubber and plastic. It's commonly done on autopia.org and various other forums. I didn't think it was some new idea.
Furthermore if you're going to get cocky, you might as well compare apples to apples. If I upgraded an assortment of parts in my engine bay, it would look like yours. This is a daily driven '97 accord with 114,000 miles on it and the only upgrade being an air intake. Everything else under the engine bay is as it was 8 years ago.
But of course you're welcome to write your own post.
Old Oct 30, 2005 | 11:09 PM
wedley2's Avatar
wedley2
bboy Wesley West
idk, but i just use foamy engine brite and some tire dresser and it looked bitching.
Old Oct 31, 2005 | 03:05 PM
delsol161's Avatar
delsol161
engine brite FTW!
Old Oct 31, 2005 | 04:08 PM
TypeG's Avatar
TypeG
i wasn't talking about rain. i was talking about laying metal foil on a starter.
Furthermore if you're going to get cocky.
how was i being cocky? by asking questions?
so what. mine is a 91, daily driven, with 210,000 miles. everything under the hood is as it was 15 years ago, but polished. later.
Old Oct 31, 2005 | 07:06 PM
redgoober4life
I eat plastic.
Sigh, nevermind. I can see the concept of water conducting electricity is beyond the scope of this thread.
And that's impressive for 210,000 miles, but this was just a cleaning.
Old Oct 31, 2005 | 08:49 PM
cobbcustomz's Avatar
cobbcustomz
Nice write up.
I know that when i clean my engine bay i cover NOTHING up. My CAI is behind my bumper tho so i am not worried about it getting wet.
Only problem i have had trying to clean my engine bay is my block tho. No mater what i try doing to it it always looks crummy
