ls/vtec parts
Old Oct 26, 2005 | 02:00 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
Default ls/vtec parts
ok i am doing my 90k tune up... do i need to get a ls or civic si parts?
i am looking at seals, timing belt, and waterpump.
and if it isnt any trouble the part #s because the queerass acura place(3 hours away) wont give the honda place(.2miles away) the part #s.
thanks guys.
Old Oct 26, 2005 | 02:17 PM
dubcac's Avatar
dubcac
I
Timing belt and water pump, get the LS for both. What seals are you looking at? If you're looking at seals that go in the head, you'd need them for the SI (assuming it's a b16 head). For headgasket, you'll need a modified OEM headgasket...check out www.goldeneaglemfg.com for good headgaskets.
As for the OEM parts, check out www.acuraautomotiveparts.org for the pump and belt.
Old Oct 26, 2005 | 03:31 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
is $200 labor good? that is how much my mechanic(former honda mechanic) is charging me. he is changing timing belt, waterpump, cam crank and valvecover seals, and adj. my valves.
is there something i am forgetting?
Old Oct 26, 2005 | 03:34 PM
dubcac's Avatar
dubcac
I
Maybe the timing belt tensioner, but most of the time they're ok. $200 labor isn't too bad.
Old Oct 26, 2005 | 03:57 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
forgot to put that in there. thank you.
so far i have come up with these part #s. please correct me it i am wrong.
Non-Vtec Timing belt 14400-P7J-004
Non-Vtec Water Pump 19200-P75-003
Tensioner 14510-P30-003
Tensioner Spring 14516-PR4-A00
Air Conditioning belt 38920-P75-A01
Power Steering belt 56992-P72-003
Alternator Belt 31110-P75-014
Valve Cover gasket 12341-PR3-000
Sparkplug seals (4) 12342-PG6-000
still looking for the cam and crank seal #s
Old Oct 26, 2005 | 04:03 PM
dubcac's Avatar
dubcac
I
For the valve cover gasket, you're going to need the one for the B16, as well as spark plug seals...I'm not sure if the spark plug seals are different, but better safe than sorry.
