Rebuilding Seized Engine (block?)
Old Oct 21, 2005 | 06:54 PM
shady visions's Avatar
shady visions
Default Rebuilding Seized Engine (block?)
I found an engine from either a 1990-93 Integra RS. The stamp on the block is B18. So it's a b18, but the transmission is automatic. ALl I really need is the head and the block anyway. However, the motor has seized up. I can get it for about ~100-150$ which I think is pretty cheap. I was just wondering if it can be rebuilt and be fixed. If so, what all would I have to do? Would it be worth it, or should I just find another motor that will probably cost me a lot more.
Old Oct 21, 2005 | 09:08 PM
dubcac's Avatar
dubcac
I
It depends on how extensive the damage is. At least rods/pistons, maybe valve/head damage, possibly a crank, possibly sleeves...you may be able to bore .25mm over and reuse the stock sleeves. You won't really know the extent of the damage until you take it apart.
Old Oct 21, 2005 | 09:56 PM
94civicEX's Avatar
94civicEX
I got worms.
I wouldn't bother.
http://www.hmotorsonline.com/shop/sc...age&item=30023
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 22, 2005 | 10:02 AM
shady visions
What all (http://www.hmotorsonline.com/shop/sc...age&item=30023) will work with my OBD0 CRX? I know I'll need a new distributor and injectors..
