difference between the pr4 heads
Old Oct 19, 2005 | 08:12 PM
whoaitslen2's Avatar
whoaitslen2
hermit
Default difference between the pr4 heads
Lets do this. Can you break down every difference between these two pr4 heads besides the valve train and stamp/casting marks? Thanks in advance.
pr4-5 off my '93 b18a1
pr4-1 off my '94 b18b
Old Oct 19, 2005 | 09:21 PM
4sd4dr's Avatar
4sd4dr
there arent any... almost 100% sure the pr4's are all going to be the same.
Old Oct 23, 2005 | 02:06 PM
dragonracingteg's Avatar
dragonracingteg
The PR4-5 is obviously looking better, but aside from that. On the left hand side of it, it has 4 markings. It might mean something??? Especially since somebody thing the PR4-1's markings should be different! It probably is nothing tho...
Here's what I found anyways...
Basically the PR4 is just saying what type of engine it's for,
the -1...-5 are the series for those types of heads
so far you should be able to just swap them and use what you like.
Deciphering the numbers on a Honda Head...
http://www.honda-tech.com/zerothread?id=721248
Old Oct 23, 2005 | 03:51 PM
dubcac's Avatar
dubcac
I
I believe they are identical. There might be minor cam changes, but I'm not sure...I haven't seen any numbers to state that they are different.
Old Oct 23, 2005 | 06:05 PM
VPUPPY's Avatar
VPUPPY
i believe those four markings you are talking about are a date stamp.
Old Oct 23, 2005 | 10:35 PM
whoaitslen2
hermit
Can anyone confirm if the intake and exhaust ports are different sizes between pr4 series/years. If anyone with any ls head just laying around can measure the inner diameter vertically and horizontally that would be dope. My digital measuring tool is broken.
Old Oct 24, 2005 | 04:54 PM
dubcac's Avatar
dubcac
I
The castings are the same for sure.
