swap motor doesn't start
Old Oct 5, 2005 | 07:17 PM
EkcivicBeast's Avatar
EkcivicBeast
Default swap motor doesn't start
me and my boy dropped a b18b1 into a 90 civic,everything is pluged in except a couple of sensors on the intake mani. when we go 2 start it it doesn't start, but its not da starter cuz we ran straight power from da battry 2 da starter n it kicked up but it was like da motor wasn't wasn't catching any spark or anything 2 kick over. The ECu is throw a electrical load detector i duno if dat has anything 2 do wit it, or if it does wat should i check on?N if not dat how do you do a spark test? thank you please explain fully oh n mind you the starter doesn't kick up if we try 2 start it inside the car
Old Oct 9, 2005 | 09:36 AM
b16ahybrid's Avatar
b16ahybrid
It's really hard to understand your ebonics, but from the sounds of it your not getting any spark.
Hook everything up then give it a shot.
It also sounds like you have a short somewhere.
