How to change Tranny Fluid?
Old Sep 27, 2005 | 06:42 AM
RBailie81's Avatar
RBailie81
Default How to change Tranny Fluid?
Ok, I'm going to change the transmission fluid in my 01 accord, I've checked some of the posts but can't find great instructions. I need to know what all is involved. I know the whole drain and drive and drain and drive procedure but I've never done stuff like this before. Usually take it to a shop but I'm low on $$$. I will use Honda ATF from the dealer. Do I need to lift my car at all, or can I reach the plug and sit a pan underneath my car? Anything else I should know or do while I'm doing this? I'm also checking my PCV valve while I'm in there.
Old Sep 27, 2005 | 07:07 AM
Powerplating's Avatar
Powerplating
Plating Guru
just tried to help
Old Sep 27, 2005 | 07:09 AM
RBailie81's Avatar
RBailie81
I thought you are not supposed to flush the trannies in Hondas.
Old Sep 27, 2005 | 07:12 AM
Powerplating
Plating Guru
[QUOTE=RBailie81]I thought you are not supposed to flush the trannies in
Old Sep 27, 2005 | 07:13 AM
Powerplating
Plating Guru
Old Sep 27, 2005 | 08:14 AM
RBailie81's Avatar
RBailie81
Originally Posted by Powerplating
Because there is no changeable filter these trans do have to be flushed
I've been told by several people not to do a flush on these transmissions. Does anyone know how much Honda ATF to buy, if I have to fill and drain a few times?
Old Sep 27, 2005 | 09:20 AM
wedley2's Avatar
wedley2
bboy Wesley West
dont do the flush, just fill and drain.
Old Sep 27, 2005 | 10:18 AM
RBailie81's Avatar
RBailie81
Where does the Fluid drain? I just looked at my engine and cant find the plug.
Old Sep 27, 2005 | 11:11 AM
JL95AccorD's Avatar
JL95AccorD
Thats because it drains from the tranny, not the engine. And yes, drain and fill, never flush.
Old Sep 27, 2005 | 01:05 PM
Powerplating
Plating Guru
