accord oem fog lights
Old Sep 21, 2005 | 04:30 PM
CL1accord's Avatar
CL1accord
Default accord oem fog lights
i was wondering if anyone knows how to hook up a daytime running light kit to the high beams and also to the oem foglights. So i could have the foglights on with the DRL and also when the headlights are on. Any wiring diagrams or how do it will be greatly appreciated. thanks
Old Sep 21, 2005 | 07:08 PM
thoughthard's Avatar
thoughthard
03-05 four door instructions... http://www.handa-accessories.com/accord/03-4drfogs.pdf
03-05 coupe instructions... http://www.handa-accessories.com/acc...drfoglight.pdf
Old Sep 21, 2005 | 08:04 PM
CL1accord's Avatar
CL1accord
thanks for the reply but i have a 2002 honda accord but it will help
Old Sep 21, 2005 | 08:14 PM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
my guess is that you would have to run an extra ground to the foglights as well. i'm guessing that either you live in canada, or that drl's are required wherever you are. all i know is that it is a royal pain in the butt do make them not work in a chevy s-10(former car), but i did it.
Old Sep 22, 2005 | 05:50 AM
flyromeo3's Avatar
flyromeo3
just wire the DRL to your fog switch.
I dont see a point in having DRL with your highbeams because u wont see the DRL with the high beams on.
Old Sep 22, 2005 | 03:32 PM
CL1accord's Avatar
CL1accord
if i do wire up the DRL to the fog switch will the drl only come on when the switch is on and also can i still use my foglights with the headlights on.
Old Sep 23, 2005 | 01:28 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
yes, drl's have a relay that shuts off, when headlights are activated.
on a note, you should have a basic understand on different types of relays and how they work before you attempt this.
Old Sep 23, 2005 | 01:37 AM
thoughthard
4dr 4cyl install... http://www.handa-accessories.com/acc...dfoglights.pdf
4dr 6cyl install... http://www.handa-accessories.com/acc...rd01fl4dv6.pdf
2dr 4cyl install... http://www.handa-accessories.com/acc...cord01fl2d.pdf
2dr 6cyl install... http://www.handa-accessories.com/acc...rd01fl2dv6.pdf
Old Sep 23, 2005 | 03:12 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
i actually think he has the foglights, and want's to know if he can wire his DRL's to it.
Old Sep 24, 2005 | 08:53 AM
CL1accord's Avatar
CL1accord
yes mrbkkt1 i already have the foglights but just wanted to know how to hook up the DRL's to the to the high beams so its at a lower wattage and also i could have the option of having the foglights on with the DRL's
