Alternater? Tell me what you think.
Old Sep 14, 2005 | 07:19 AM
FireGuySith's Avatar
FireGuySith
Default Alternater? Tell me what you think.
okay, yesterday i had to jump start my car twice. seems as though the battery was really low (not completely dead). after the second jump start i left the engine running so the alternator would recharge the battery. i shut off my engine and then tried to start my car but the battery was still too low to start. i'm thinking that its either the alternator or the battery cable. Tell me what you think. thanks for any input. ^_^
Old Sep 14, 2005 | 07:25 AM
See any signs of alternator issues? (high pitch squeeling in the speakers, strange dash lights)
Sounds like the alternator to me ... but .. how old is the battery? sometimes they just can't hold a charge anymore.
Old Sep 14, 2005 | 07:27 AM
Misa's Avatar
Misa
Pic Whore
try cleaning the battery terminals and cables.
wouldnt hurt to try :dunno:
Old Sep 14, 2005 | 07:56 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
This sounds more like dead battery than alternator.
Pop off the little plastic covers on the top of your battery and see if the acid is covering the electrodes. If not, add some DISTILLED water to it temporarily but replace ASAP.
Old Sep 14, 2005 | 07:58 AM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
Default or
you can start your car and disconnect the positive side on your battery while the car is running. if the car shuts off when you disconnect the possitive side, then its your alternator. if it doesnt shut off then it might just be the battery.
Old Sep 14, 2005 | 09:25 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
time for Optima Red Top for you.
Old Sep 14, 2005 | 09:35 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
^gtfo.
Old Sep 14, 2005 | 11:57 AM
JimBlake's Avatar
JimBlake
Got a voltmeter? I'm surprised nobody suggested actually measuring your charging voltage.
Engine running, should be above 13 volts.
Engine running, turn on everything you can find. Lights, wipers, blowers, amplifiers, windows, whatever. It should not drop much.
If it can't hold 13 volts when the engine is running, your alternator isn't working. First check all the wiring connections at the battery, alternator & ALL the grounds.
Old Sep 14, 2005 | 08:32 PM
FireGuySith
CRAPXORS!!! i wish i waited. I already bought an alternator and installed it.
after i bought the alternator, i let the car idle to recharge it, but that didn't work. after that i went to autozone and got the battery tested. They said it was bad (dude said that a bad battery has a certain smell). So i got a new battery and now everything is fine, except for the fact that i waste $115 on the alternator. Thanks for the Help though guys. Now i know, and knowing is half the battle
Old Sep 14, 2005 | 09:30 PM
wedley2's Avatar
wedley2
bboy Wesley West
just save it for later
