Performance chip for '97 2.5 TL
Hey.
Does anyone know where the Intake Air Temperature Sensor is located on the '97 2.5 TL?
The chip I just bought is supposed to connect there.
Also, if anyone has any info. on replacing the stock gauges in the TL with aftermarket reverse light gauges, I'd appreciate it tons!
Thanks.
Thanks.
As for the "performance chip" I would NOT intall it on your TL. It's a sham. It basically makes the ECU read lower temp readings than what is there, in turn dumping more fuel in. This is not beneficial and can actually be harmful to your motor.
