hey honda heads i need some help!!!
alright guys heres my problem. i have a problem with my 91 integra with gsr swap. mind u that the car is obd-0. ok my problem is that when i drive the car the car like boggs bad with little bit of throttle, also when i drive the car and switch gears like 1st to 2nd the car kinda boggs a little bit there to until i it gets more throttle. i think its like a fuel problem. it feels like u know when u run low on gas and your car jumps and boggs around because of fuel starvation. also the intake is all you here when the car boggs like it sucking in air but no fuel to match it. i am throwing codes 13 baro sensor and 20 electrical load dectector. now i dont know if the cel haves anything to do wit it but i thought it help. the only other thing that puzzles me is that also the car is running rich. please guys help me out here im stumped
p.s. also i have checked the map sensor, replaced it, tps sensor nothin. a friend of mine is gonna let me borrow fuel pump relay but i dont think that will help me fix it
i am currently running the pm6 ecu chipped but i gonna get a pr3 soon to see if that is the problem. also i have checked my timing over and over again. still dont kno what the problem is, i know i have code 13 and 20 but could that be the problem that is making me bog?
i dont have any cam gears stock p72's and i dont even kno where my baro sensor is located. also i switched out my ecu back to stock ls pr4 and now i am throwing a code 43 something wit the fuel pressure. but please can someone give me some info on the code 43 it would help out alot. thanks dough
Last edited by azndough; Aug 1, 2005 at 02:37 PM. Reason: figured something else out
