Blue 2000 Civic Si FASTT
Blue 2000 Civic Si
Engine and Performance:
LS VTEC
B18B Bottom End B16 Head
Mild Port and Polish
JE Pistons 12.5:1 Compression
Cometic Turbo head Gasket (Lowers to 12:1)
Eagle Rods
ARP Head Studs
Prelude 290 CC Injectors
Micro Polished Crank
Balanced and Blueprinted Rotating Assembly
Type R Oil Pump/Cooler
Skunk2 Stage 1 Cams
Supertech Valve Springs and Retainers
Ferrea Valves
Password JDM Power Chamber Carbon Fiber Intake
JDM DC SS 2.5 Inch Collector Header
Test Pipe
Apexi N1 Cat Back Exhaust
Skunk2 Short Throw Shifter
Prothane Shifter Bushings
AEM Underdrive Pulleys
Skunk2 Intake Manifold
Type R Throttle Body
OBD1 ECU Conversion
Chipped P28
Hondata S200
Exedy Organic Clutch
Looks and Suspension:
Eibach Sportline Springs
Tockiko Blue Shocks
A-Spec-Racing Sub Frame Reinforcement Kit
ITR 22mm Sway Bar
Stock Rims and a comes with Azenis
set of all seasons
Skunk2 Camber Kit
Factory Fog Lights
Civic Type R Headlights
Factory 99-00 Rear Lip
Shaved all "H" Logos
Window Tint
PowerSlot Rotors
Hawk HP Pads
Goodridge Steel Brake Lines
XenonDepot.com 4300 HIDs
Inside:
Custom Katskins Leather Interior with "Si" stitched in the Head rests
Autometer Carbon Fiber A/F Gauge and Oil Pressure Gauge
PICS
http://www.brokenlimits.com/2000civi...y/DCAM0059.JPG
http://www.brokenlimits.com/2000civi...y/DCAM0066.JPG WILL DELIVER 13000 FIRM THIS THING IS FASTTTTTTTTTT!!!! PM ME
LS VTEC
Eagle Rods
ARP Head Studs
Skunk2 Stage 1 Cams
Ferrea Valves
Test Pipe
OBD1 ECU Conversion
Chipped P28
Hondata S200
Tockiko Blue Shocks
ITR 22mm Sway Bar
Skunk2 Camber Kit
Factory Fog Lights
Window Tint
PowerSlot Rotors
Hawk HP Pads
Inside:
PICS
** Addendum New Rule: Please Note the State of Where Vehicle is Being Sold
Effective 11/29/04
Please, as courtesy to potential buyers, note the state or providence of where the vehicle is located.
Example:
FS: 1998 Acura Integra; SoCal
Thank you all for your co-operation.
Effective 11/29/04
Example:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
