FS in Colorado: 457 whp 5th gen Civic Sedan
Old Jul 5, 2005 | 10:04 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default FS in Colorado: 457 whp 5th gen Civic Sedan
SOLD BITCHES!
PRICE RECENTLY UPDATED, PLEASE PM OR EMAIL ME IF INTERESTED.
THIS SALE IS FOR SERIOUS BUYERS ONLY - IF YOU DO NOT THINK YOU CAN AFFORD THIS CAR OR ARE JUST CURIOUS ABOUT IT, MOVE ALONG. I WILL ONLY ENTERTAIN SERIOUS INQUIRIES!
Well ladies and germs, I've decided that it's time for me to move on to another vehicle so I'm selling the beast.
Videos:
374 WHP dyno run: http://www.savefile.com/filehost/files2.php?fid=6460148 (updated)
13.36 1/4 run in 2002: http://www.savefile.com/files/4526052 (stong language)
Images:
**** PICS TAKEN & ADDED 7-11-2005 ****
Mods are as follows:
Engine Modifications:
Block
- B18C1 Swap
- AEBS T-Sleeves installed by AEBS
- Cylinders bored to 84mm
- Custom ROSS 84mm 9.5:1 pistons
- Pauter I-Beam Rods
- ARP rod bolts
- AEBS main studs
- ACL main bearings/rod bearings/thrust washers
- Balanced & blueprinted crank, rods, pistons, flywheel, clutch, and crank pulley
- Full new conversion kit (bottom end gasket set - Summit Racing)
- Energy Suspension and Prothane motor mount inserts
- Hyper ground wire kit
- Custom 2.5" exhaust to Random Tech 2.5" CAT to an Apexi N1 muffler
- DC Sports battery tie-down (polished)
Head
- Port matched on the intake side
- Port matched on the exhaust side
- 3 angle valve job
- Decked
- AEBS Head studs & nuts
- Acid dipped & glass bead blasted head
- All new head gasket/seal set (OEM Honda)
- Cometic 84mm head gasket
- JDM ITR red valve cover
- Skunk2 polished intake manifold port matched to head
- Hondata intake gasket
- Carbon fiber wire cover
- Magnacor 10mm plug wires (red)
- MSD Blaster external coil w/ distributor cap
- NGK-R spark plugs
- AEBS cam seal
- OEM JDM ITR cams
- AEM 5-bolt cam gears
- Supertech titanium retainers
- Rocket Motorsports Gen1 valve springs
Fuel
- AEM fuel rail (red)
- AEM high flow fuel filter (silver)
- RC 650cc injectors
- AEM adjustable fpr
- B&M fuel pressure gauge
- Walbro 255 LPH HP fuel pump
Cooling
- GSR OEM radiator retrofitted w/ custom mounts
- FAL Civic fan fitted onto the GSR radiator w/ custom mounts
Drivetrain
- OEM GSR Transmission
- OEM axles
- ACT XTR6 clutch/pressure plate
- Energy Suspension shift linkage bushings
- Skunk2 dual-bend short shifter
- Clutchmasters 7.5lb flywheel
Turbo
- MaxRev kit
- MaxRev shorty manifold - polished
- MaxRev 2.5" downpipe
- Garrett T3/T04E 57 trim .60 A/R turbo
- TiAL 35mm wastegate w/ .75 BAR 'big yellow' spring
- HKS SSQ BOV
- Greddy Type 24 FMIC
- Greddy Full Auto turbo timer
- Greddy Profec-B Spec-II boost controller
- Custom 2.5" intercooler piping
- Apexi Power Intake filter
- Hondata 3BAR MAP sensor
Engine Management
- OBD1 P72 ECU
- Hondata S200B w/ datalogging and 3step rev limiter (soon to be Neptune)
Dyno Results & 1/4 Mile Times
- 457 whp / ~370 wtq @ 22.5psi @ 8000 ft elevation - Dyno Sheet
- 12.607 @ 114.86 @ 12.6psi on street tires (Falken Ziex) - Timeslip 1 - Best Time Yet / Timeslip 2 - VS a WS6
Suspension & Brake Modifications:
- Koni Yellows
- Skunk2 coil-overs
- Neuspeed front-upper strut tower brace
- Energy Suspension full bushing kit
- Brembo blanks (stock replacements)
- Nissin brake pads
- GSR rear LCAs
- ITR rear sway bar w/ custom fit Beaks mount kit & Prothane bushings
- GSR front LCAs
- GSR front sway bar w/ Energy Suspension bushings
- GSR Master Cylinder and Brake Booster
- 1993 Integra LS nonABS proportioning valve
- Full front and rear GSR disc brake upgrade
- Earl's stainless steel brake lines
- Axxis Ultimate brake pads (F)
- Axxis Metal Masher brake pads (R)
- Rota 16x7" Slipstreams in gunmetal with a polished lip (13.5 lbs/ea)
- Falken Ziex 205/45/16's
- 2 Konig 15x6.5" Heliums in bronze (11 lbs/ea - used only for drag racing)
- 2 BF Goodridge T/A Drag Radials 205/55/15
- Kyokugen JDM keyed Gunmetal lug nuts
- Omnipower front-upper A-arms w/ camber adjusters
- Ingalls rear camber adjusters
Exterior Modifications:
- JDM EG9 headlights w/ Raybrig H4h bulbs & PIAA Xtreme white city lights --- The city lights are wired as they are wired in Japan. When the parking lights are turned on only the city lights illuminate with the tail lights. The corners only illuminate when the turn signal is engaged.
- JDM EG9 clear corners
- JDM EG9 sidemarkers
- Red/clear taillights
- ABS Mugen replica front lip
- EK side skirts
- ABS CTR replica rear lip
- TC Sportline OEM-look carbon fiber hood
- JDM EG9 Ferio sail covers
- JDM EG9 Ferio trunk lid
- JDM EG9 Ferio rear spoiler
- JDM EG9 Ferio rear trunk emblem
- JDM rear Civic emblem
- JDM rear SiR emblem
Interior Modifications:
- JDM clock
- JDM climate control face and orange backlighting
- JDM coin pocket
- GSR gauge cluster w/ orange backlighting
- ITR style shift knob
- OEM optional armrest
- Greddy EGT gauge
- Autometer Z-series oil pressure gauge
- Paintmatched 2 gauge pillar pod
System:
- Sony eXplod 50x4 dual face head unit
- MB Quart component set / 6" mids & 1" tweeter
- Polk Audio 6.5" coaxials in the rear
Alarm:
- Blackwidow with keyfob pager
Photo Galleries:
Exterior: https://www.honda-acura.net/forums/s...d.php?t=161485
Engine (rebuild in progress): https://www.honda-acura.net/forums/s...d.php?t=142746
http://s115824406.onlinehome.us/_josh/joshAndDavid2.jpg
http://s115824406.onlinehome.us/_josh/joshAndDavid.jpg
https://www.honda-acura.net/forums/a...id=43540&stc=1
https://www.honda-acura.net/forums/a...id=43541&stc=1
Pretty recent (exterior): https://www.honda-acura.net/forums/s...d.php?t=183245
Latest parts: https://www.honda-acura.net/forums/s...d.php?t=188670
Dyno info: https://www.honda-acura.net/forums/s...d.php?t=190339
My Garage: https://www.honda-acura.net/forums/v...o=view&id=1197
Search all forums for 'pics' posted by me, and I'm sure you'll find more.
ITEMS INCLUDED IN SALE:
• Everything listed above
• 1998 Integra LS manual tranny
• 2 15x6 Konig Heliums (11 lbs/ea) w/ great condition BF Drag Radial 205/55/15
• Honda OE leather full front bumper cover (bra)
• Honda OE leather front hood cover
• Brand new brake master cylinder (installed)
• Brand new Falken Ziex 215/40/16 tires (w rated)
• Integra GSR gauge cluster (car is wired)
• Civic EX gauge cluster w/ carbon fiber gauge bezel (car is wired)
• Full set of OEM rims for snow tire use
This car was the February 2004 Featured Ride
I have receipts for almost everything that is currently installed on the car and any mod/admin on here or those listed in my feedbacks can vouch for me and this car. I can provide any information you need and pics of anything as well. This is a nasty car (power-wise) and reliable as a daily driver. There are about 110,000 miles on it, but the interior and body are really the only parts that are not new. The body has minor wear and tear blemishes, as does the interior (no holes or cig burns). The car has never been smoked in and I am the second owner.
My thoughts toward the sale price of this car is pretty much up in the air. I know I have around $30k into the car, but... it's a Civic so I don't have any delusions of grandeur. The blue book value of the car is apprx. $4,000. Don't offer me this or I will laugh at you and you will feel stupid. h:
I have modded this car with a 'non destructive' mentality so there are not unused holes anywhere on the car. The engine wiring has been done with care and precision as has the rest of the mods. I am a perfectionist so you can be assured that the car is in great condition.
Thanks, and please bump this often.
Josh
Old Jul 5, 2005 | 10:23 AM
Outxider's Avatar
Outxider
X-Motoring
omg ur sellin the 4door beast. i understand, u gotta do what u gotta do. hope this beast goes to a good home. just curious josh, what next project do u have in mind?
Old Jul 5, 2005 | 10:26 AM
westcoaststyle
Thanks man! You and many other OG's have definitely been a huge part of this car. I owe you guys a lot.
Next car: '05 Lexus IS300 :naughty:
Old Jul 5, 2005 | 12:58 PM
thomas's Avatar
thomas
pew pew pew
wow sad to see it go man, bump for a awesome car....
Old Jul 5, 2005 | 01:27 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
hey man its sad to see the beast go. are u still gonna to stay with HAN? Im gonna to be rebuilding my engine in hopes to be in the level of proformance that you have gotten to. to the best of luck for you. Whats ur plans for the IS300? U planin on geting the charcoal grey pearl one? I have seen many of those which can b/c a beast with the right mods.
Old Jul 5, 2005 | 01:36 PM
westcoaststyle
I think my first mod will be some deep dish 18's. I don't know that I'll make this one fast like I did with the Civic. I just want something that I can be comfortable in. I might turbo it down the road.
Thanks for the props man. Spread the word; I wanna get this ol' girl sold.
Old Jul 5, 2005 | 03:40 PM
prelood's Avatar
prelood
Bump for a beautiful/fast Spivic.
Nice choice for a next car :thumbup:
Old Jul 5, 2005 | 07:15 PM
Nelson's Avatar
Nelson
Administrator
Another one bites the dust
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jul 5, 2005 | 07:44 PM
westcoaststyle
Indeed
Old Jul 5, 2005 | 09:50 PM
Outxider's Avatar
Outxider
X-Motoring
i dl a video bout 2 months back, this dood with a is300 graphite grey pearl drop in a 2jz-gte and his friend filmed him rappin numerous american muscle cars on the freeway including ss maros, svt, gts, ws6, ect. all classic footage cuz the faces of the unsuspectin victims were like this :eh: . anyhoo, bump for a great seller. any offers yet josh?
