F/S 92 Civic VX w/ B20/VTEC in Missouri *56k warning*
well since my last thread was closed because my location wasn't in the title i had to make a new thread. so anywayz, the hatch is still for sale.
the good stuff:
92 Honda Civic VX
150,xxx miles on chassis
10,xxx miles on motor
B20/Vtec motor
98 CRV B20B bottom end
92 Civic SiR B16 head
96 Integra LS transmission
Web Turbo cams
Web dual valve springs
Web .5mm oversized valves
Titanium retainers
head was ported and polished and put together by kenny at KG engineering.
AC fuel rail
Walbro 255lph fuel pump
B&M fuel pressure regulator
DSM 450 injectors
95 accord injector resistor box
JG Edelbrock Victor X intake manifold
AEM short ram intake
DC Sport 4-1 ceramic header
Apexi N1 turbo muffler
MSD 6AL ingition box
MSD Blaster 2 ignition coil
MSD Pro distributer cap (clear red)
Nology Hot Wires
Sage Racing voltage regulator
generic oil catch can
AEM cam gears
ACT 6 Puck clutch disc
ACT Heavy Duty pressure plate
ACT Prolite Flywheel
Apexi VAFC 2 black face
generic front upper, rear upper and c-pillar tie bars
DC Sport rear lower tie bar
Prothane engine mount inserts
generic coilovers on stock struts
2000 SI wheels tires on the wheels are bald, but new tires are being put on this weekend
95 del sol rear disc brake conversion
Top Speed short shifter
Tinted A/F, Boost (was going turbo), and oil pressure gauges in a-pillar triple gauge pod
Direct port nitrous kit not installed yet
now the bad stuff:
- the car needs to be sanded and painted it was keyed and hasn't been painted yet.
- there is a little bit of rust on the right rear wheel well
- the throw-out bearing needs to be changed
- valves need to be adjusted
there might be other small stuff but that is the biggest problems. i may be missing other parts also but it's hard to think of everything right now. i'm asking $6,800 obo
now to the pics
the good stuff:
92 Honda Civic VX
B20/Vtec motor
Web Turbo cams
Titanium retainers
AC fuel rail
DSM 450 injectors
Nology Hot Wires
AEM cam gears
now the bad stuff:
now to the pics
