help from honda techs please
Old Jun 24, 2005 | 07:52 PM
taz77's Avatar
taz77
Default help from honda techs please
and i mean someone who's a tech at a honda dealership or has access to the same information...
i've got a mil/cel with 2 codes... p0700 and p0740... lock up control circuit if i remembered correctly. comes on whenever i drive at a steady 55mph +/- 5mph for 1 minute.
i've read somewhere that there is a TSB for these two codes that comes on after replacing a transmission, however, i do not have access to honda's TSBs and do not know what the cause and fix is.
can someone look up (or have first hand experience with this) please give me some insight on the fix to this problem? thanks
tim
Old Jun 27, 2005 | 11:04 AM
mkenniston's Avatar
mkenniston
Default Transaxle codes
Check your transmission fluid levels first. Is your engine running smooth? Maybe try adjusting the throttle control cable. Could be the shift lock solenoid. Could be a lot of things. Good luck.
