1998 2.3 CL shuts down while engine is on
Old Jun 24, 2005 | 06:43 AM
Livan Roque's Avatar
Livan Roque
Default 1998 2.3 CL shuts down while engine is on
I need help desperately,
My 1998 2.3 CL engine stops while i am driving the car. It starts fine but then when i put it in gear and starts moving it suddenly stops with no warning. i have flushed the injectors, changed sparks all most minor things i can think of. can someone help me diagnose what could be the cause/s of this problem. no time/money for mechanics.
thanks
if anyone could write me back in Spanish it will help greatly
Old Jun 24, 2005 | 09:32 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Have you tried checking the battery connection? Sometimes if your terminal connections are loose, your car might start but as soon as there is some movement and it loose contact, your car might die. Also, do you have low idle? You need to explain youru situation in more detail as it could be multiple things.
