clutch or master cylinder
Old Jun 21, 2005 | 01:52 PM
pragl's Avatar
pragl
Default clutch or master cylinder
I have a 1998 acura integra with 205,000 miles. over the past month i've had some chatter in my clutch when in gear and finally yesterday all the pressure went out in the clutch and i couldn't get it in gear. The clutch never slipped but now i just cant get it in gear unless i turn the car off. Now, when i turn it off and put it in gear the car will move even iff the clutch pedal is pressed to the floor, furthermore there is absolutley no resistance in the clutch/ no pressure. Is this a master cylinder issue/ slave cylinder issue/ or clutch issue. The pedal does return but with no pressure. I was told to look for any leakage under the car but i didn't see any can someone help me?
Old Jun 21, 2005 | 02:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you would have scrolled down a bit before posting, you would have found this: https://www.honda-acura.net/forums/s...d.php?t=193892
Welcome to HAN and good luck with the problem.
Old Jun 23, 2005 | 10:06 AM
ksolo101's Avatar
ksolo101
Sounds to me like the same exact problem i had about 3-4 weeks ago
Which turned out to be the Master Cylinder -Good Luck
