Weird sound from engine...
Old Jun 17, 2005 | 06:26 AM
blue600rr's Avatar
blue600rr
Default Weird sound from engine...
Lately, my engine has been making a weird grinding sound from the engine (i think it's the valves or something" around 1500-2000 rpm! Does anybody else have this problem? Everytime I shift, it always makes the weird sound around that RPM...What could be wrong with it, and how do i fix it?...and I just hit 63000 miles. The car runs real good, but sometimes it makes that sound!
Old Jun 17, 2005 | 08:40 AM
VTEC-Power's Avatar
VTEC-Power
You have oil in the car?
Old Jun 17, 2005 | 09:15 AM
blue600rr's Avatar
blue600rr
yes...checked oil and everything...oil level is between the 2 dots...
Old Jun 18, 2005 | 01:47 AM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
Could be the throw out bearing in the clutch
Old Jun 18, 2005 | 02:07 PM
blue600rr's Avatar
blue600rr
What is a "throw out bearing"???...can you explain a bit more????
Old Jun 18, 2005 | 07:25 PM
diamondsleeper
1990 & 1991 Si 2.05
Throw out bearing: When you step on the clutch pedal you're pushing the friction plate away from the clutch disc and flywheel to disengage the clutch.
Of course this is a rotating component. The component that pushes on this when you step on the clutch pedal is stationary. There has to be some way of pushing a stationary component against a rotating component. The throw out bearing is what is between the stationary component and the rotatiing component. This bearing can wear out. When it does it can make noise.
Old Jun 18, 2005 | 08:06 PM
pUrExTc's Avatar
pUrExTc
殺生丸
can you describe this sound?
Old Jun 20, 2005 | 09:24 AM
blue600rr's Avatar
blue600rr
it sounds like gears that does not have enough lubrication or something like that. i'm assuming it's the oil, but then when i check the oil fluid, it is fine. so what could it be?...should i just pour in more oil?
Old Jun 21, 2005 | 08:12 AM
diamondsleeper
1990 & 1991 Si 2.05
Is the noise there all the time or just when you step on the clutch?
Old Jun 21, 2005 | 04:09 PM
blue600rr's Avatar
blue600rr
it's not all the time...it's only sometimes... it doesn't matter if im stepping on the clutch or not...it makes the sound regardless...
