Amp self-install, want tips on minimizing interference & stuff
Hey,
I'm installing an Eclipse 50x4 RMS amp under the passenger seat of my 94 Prelude Si. I'm pulling out the whole interior and I only want to do this ONCE, so I'm looking for all the pointers I can get. I'm on a steep car-audio learning curve here.
I've got 6-foot RCAs, directional double-shielded, gonna go down the center divider. They were each $9. Got 8-guage ground and power wire, the ground will just go straight to the nearest steel beam and the power goes down the passenger door sill.
My concerns:
Screwing the amp to the floor: will it produce interference? I'm especially concerned because I'm installing sound deadening material all around, which has an aluminum backing. I don't really want to eliminate it under the amp. I need to insulate the amp mounting points somehow.
Power to the battery: I'd like to route it so it hugs the chassis. Then it's out of the way and I can screw my fuse holder to the chassis. Is it a problem to have the + and - power channels right up against each other for several feet?
Any installation tips would be greatly appreciated.
Thanks,
-Dan
My concerns:
Thanks,
-Dan
The positive wire goes one way to the battery in my car and the negative ground goes the opposite direction to the grounding point - it's better IMO to keep them apart but if you run them the same direction, keep your distance between the amp and grounding point as short as possible, ideally like 1-2 feet. There's really no need to run them the same way though since they're not going the same place.
Thanks.
Dan
Fuse your main power cable close to the battery. Within a foot or so. You should be fine going through the sound dampening. I screwed my ams right to the floor under the seats and never had a problem. If the rcas are directional make sure to pay attention to the arrows and which way they are supposed to go in. It wont matter if the + wire is near the chassis. I dont see any way how you could possible have it far enough away even if you wanted to.
