H22 H23 Motor
Old May 21, 2005 | 11:21 PM
jdmdelsolguy's Avatar
jdmdelsolguy
Default H22 H23 Motor
ok Iwas wondering if you could run OBD1 H22 injectors in a H23 Vtec motor with out any problems
thanks
Old May 22, 2005 | 12:06 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I believe they are the same flow rate. I don't even think you need to alter the harness.
You will not see any gain out of it, but if you cannot find direct replacement for the H23 injectors, those will suffice.
Old May 22, 2005 | 07:16 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
From what I gather, H22's are 345cc and H23's are 240cc. Not sure, just stating what I've read before in another thread.
Old May 22, 2005 | 10:20 PM
Provocateur
On permanent hiatus
No way. Stock GSR injectors are 240cc, so why would an H22 motor producing 117% more horsepower need 143% larger injectors?
I think most, if not all, Honda injectors are 240cc size.
Old May 23, 2005 | 12:11 AM
stereo's Avatar
stereo
the 5g prelude injectors are 290 from what I heard but the 93-96 one did have 300+ injectors not sure why but it's most likely just because of the program they are using on those ecu's as the prelude ecus are still a mystery.
Old May 23, 2005 | 02:24 PM
2legit2quit
You Big Dummy
Like I said, I'm not certain, but that's what I think they are.......definatly could be wrong though. I'm gonna find out for sure now that I'm thinkin' about it.
Old May 23, 2005 | 02:52 PM
2legit2quit
You Big Dummy
Correctamundo.h: http://www.robietherobot.com/storm/f...ectorguide.htm
So jdmdelsolguy, you have a H23/VTEC motor? If so, it might be a good idea to put those injectors in.
Old May 23, 2005 | 08:59 PM
Provocateur
On permanent hiatus
Good find. I guess I learn something new everyday.
