I want to make my b16a3 fats as shat
Old May 7, 2005 | 01:17 PM
gordis's Avatar
gordis
Default I want to make my b16a3 fats as shat
What can I do?
I want opther options than getting a turbo
fuel injectors? nitrous? etc? what should i get to make me go that much faster?
thanks
Old May 7, 2005 | 01:19 PM
teg92's Avatar
teg92
WHAT OK YEAH!
New Valvetraine, cams, cam gears, valves, pistons, rods etc.. Pretty pricey though, Fuel injectors wouldnt do much and nitrous will probally damange your engine
Old May 7, 2005 | 01:20 PM
gordis's Avatar
gordis
how much more power would i expect to gain? from thoise things u listed
Old May 7, 2005 | 01:21 PM
teg92's Avatar
teg92
WHAT OK YEAH!
NA you can probally get 180-200 WHP depends on how its built and what parts you use
Old May 7, 2005 | 01:24 PM
gordis's Avatar
gordis
if i was to go the turbo route...what would eb the cheapest and best kit to use?
Old May 7, 2005 | 01:48 PM
Mario's Avatar
Mario
Definitely the turbonator. It sounds like a perfect setup for you. :goodjob:
Old May 7, 2005 | 01:55 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
theres only so much N/A building you can do if you plan on using pump gas... also a wicked all motor b16 would be a pain in the ass in many normal driving conditions. If you can't turbo, I'd get a wet nitrous kit and squeeze off 50hp shots... that in conjunction with some other thoughtful mods (i.e. moderate cams, I/H/C/E, etc.) would be pretty peppy. As long as youre smart with it, nitrous is no more dangerous than boosting. Another potentially quite powerful (although not as economical) option would be supercharging. That can also be done in conjunction with nitrous, but that would be pushing it for stock b16 internals.
Just curious, why wont you turbo? Because thats really the best way to make your motor "fats as shat." :chuckles:
Old May 7, 2005 | 01:57 PM
white_n_slow
it's my D in a B
:chuckles: i heard that thing was awesome!
Old May 7, 2005 | 02:32 PM
Bricks2k4civic's Avatar
Bricks2k4civic
I have that. I get about 50 miles to the gallon, and it added 200whp alone!
Old May 7, 2005 | 06:56 PM
ED9man's Avatar
ED9man
driver
Not to mention a monster N/A will have even less low end torque than stock, which is already lifeless below 3000, even in my car which is the lightest chassis you can put it in.
