Intake Manifold
Old May 2, 2005 | 09:25 AM
hurleyguy145's Avatar
hurleyguy145
d16y8 bolted uP^
Default Intake Manifold
b16a1 IM on d16y8 What do you think? Worth the time?
Old May 2, 2005 | 09:30 AM
thomas's Avatar
thomas
pew pew pew
i dont think that it will fit at all
Old May 2, 2005 | 09:37 AM
Running925's Avatar
Running925
Your Powder Coater
B-series / D-series not compatible!
Old May 2, 2005 | 10:43 AM
1fasthb's Avatar
1fasthb
Sorry. It won't even come close to bolting up.
Old May 2, 2005 | 10:52 AM
hurleyguy145
d16y8 bolted uP^
*hits self* i thought i read that it could....alrite well thnx
Old May 2, 2005 | 10:53 AM
hurleyguy145
d16y8 bolted uP^
well then hell, skunk2 IM or other brands etc - worth while?
Old May 2, 2005 | 11:05 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Depends on what all you have done. There are some seriously badass manifolds out there, but you need to be making a good deal of power already to make full use of them.
Old May 2, 2005 | 11:24 AM
Running925's Avatar
Running925
Your Powder Coater
to back up this post, i'd like to make sure that that this is also stated.
Our car's stock manifolds are designed to flow much more air than they actually flow as a stock motor. Therefor you are able to make some upgrades & not even worry about air flow for a while. Example, sticking a header & an intake on a stock motor is worthless. The only gain would be the K&N style filter due to the fact that it wouldn't be as restrictive, BUT the amount of difference that the filter would make, is not going to be noticeable to the eye or feel of the vehicle so to say.
Hope that helps some of u guys out there.
