Your car's wiring diagram
Old May 1, 2005 | 11:10 PM
Sh22awndo's Avatar
Sh22awndo
Default Your car's wiring diagram
If you will just tell me the year, make, and model-i can give you a complete list of you vehicle's wiring diagram.]
For instance:
95 Acura Intergra
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 1995 / Remote Start
Item----wire color--poloraity--location
12volts white (50A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black (not required) + ignition harness
Keysense blue/white to lt. blue - ignition harness
Power Lock black/white - driver kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock black/red - driver kick panel
Lock Motor white/red 5wi lock control unit in driver door
Unlock Motor yellow/red 5wi lock control unit in driver door
Parking Lights+ red/black + green plug above fusebox
Notes: Also a male blade terminal is available in fuse box.
Parking Lights- blue/red - factory alarm (if equipped)
Notes: The factory alarm is under the driver seat.
Hazards same as turn signal wires
Turn Signal(L) green/blue + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + driver kick, harness to rear
Door Trigger lt. green/red - driver kick panel
Notes: Looks like 14 awg wire but mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Pin green - blu 12 pin plug, top ctr of fuse box
Hood Pin yellow/red - driver kick panel
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac distributor
Notes: Also found in a 16 pin white or gray plug to the left of the fuse box.
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake green/red - parking brake switch
Horn Trigger gray to blue/green - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Old May 2, 2005 | 04:36 AM
96 Acura 2.3 TL, thanks
Old May 2, 2005 | 07:05 AM
99IntegraGS's Avatar
99IntegraGS
Are there any changes from the '95 Integra listing for the 98-01 Integras? I have a '99...
Old May 2, 2005 | 08:17 AM
Sh22awndo's Avatar
Sh22awndo
The 96 Acura TL is as follows
DIRECTWIRE™ WIRING INFORMATION - ACURA / TL / 1996 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Power Lock gray - passenger door harness
Power Unlock green/yellow - passenger door harness
Lock Motor white/red driver kick panel
Unlock Motor red driver kick panel
Parking Lights+ red/black f-box, dr. kick, or dimmer
Parking Lights- red/white security control module
Notes: Security control module located high on passenger side behind the glove box and the ABS control unit. Locate wires in harness that drops down from module.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger black/white - plug at inst. cluster
Notes: May also find individual door triggers at security control module. They are as follows, drivers door is grn/blu, front passenger door is grn/red, left rear door is grn/yel, and right rear door is grn/wht.
Dome Supervision
Trunk/Hatch Pin orange - plug at inst. cluster or DKP
Hood Pin yellow/red - security control module
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Notes: To disarm without unlock 1) Find the green/yellow unlock wire at the factory alarm. 2) Cut the wire and place a diode inline with the stripe away from the factory alarm. 3) Tap between the diode and the factory alarm for your disarm without unlock.
Tachometer blue AC
Notes: On the 2.5 find the blue at the coil next to the battery. On the 3.2 find the blue at the white 2 pin tach test plug at the passenger rear side of the motor to the left side of the ABS modulator unit, next to an orange 2 pin plug.
Wait to start
Brake Wire green/white + left kick in harness
Parking Brake
Horn Trigger blue/red - security control module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old May 2, 2005 | 08:21 AM
Sh22awndo's Avatar
Sh22awndo
According to DEI there insn't. It should be the same as the one listed above. But to my experience no two cars are exactly alike!
Old May 13, 2005 | 04:46 PM
Poorboyz's Avatar
Poorboyz
Can you please give me the diagram for a 1993 Civic Hatchback 5 spd DX model.
I'm trying to put in a starter kill switch and a fuel cut off switch.
Thank you
Chuck
Old May 14, 2005 | 03:27 PM
TTT's Avatar
TTT
97 civic ex
thanks alot man!
Old May 14, 2005 | 04:15 PM
santa1666's Avatar
santa1666
I have 98 acura TL 2.5
Old May 16, 2005 | 06:13 AM
yang72881's Avatar
yang72881
1993 Honda Accord Ex
Old May 17, 2005 | 11:38 AM
JoeC05's Avatar
JoeC05
Default Car diagram?
Hey, i have a 1992 Honda Accord Ex and a 1999 Acura 2.3 CL (if too much, the accord would help me out ALOT!) thanks.
